What grease to use for axle/similar parts? - 600RR.net
post #1 of 10 (permalink) Old 02-26-2016, 05:33 AM Thread Starter
jawsolsen333's Avatar
like the title says. white lithium grease, lithium grease, silicone, i heard belray waterproof grease is good.
open to suggestions, my rear axle is pretty dry and since i'm taking the tires off, i figured i'd grease up some parts around there since it was probably never lubed up since the factory.
Thanks!
edit* and also I dont care for getting some top of the line stuff. Anything that will work good and isn't highly priced!
jawsolsen333 is offline
post #2 of 10 (permalink) Old 02-26-2016, 06:20 AM
Soponcio Virtual's Avatar
It's just grease... Exactly for the axle you don't need a particular grease since there is not much heat around that area (lithium grease bares a lot of temp).
Get yourself some lithium grease (the colour is not important), I use it for most of the stuff on the bike. It exceeds what you need but you'll find it usefull on other parts of the bike.
Honda CBR600RR 2003 - Gone! (the blond)
Honda CBR600RR 2007 - On the road! (the brunette)
Soponcio Virtual is offline
post #3 of 10 (permalink) Old 02-26-2016, 07:37 AM
Miweber929's Avatar
I generally use a marine grade grease on things like wheel bearings and axles. The marine stuff is for use in environments that see a lot of water so it won't wash away as easily.
Big tubes available from Walmart, same thing with white lithium grease which also works well.
Don't overthink it; it's grease.
- '17 Ducati Supersport S
- '13 Kymco Super 8 150
- '11 Triumph Sprint GT
- '04 Yamaha WR450F
- Past rides: too many to list
Miweber929 is offline
post #4 of 10 (permalink) Old 02-26-2016, 10:01 PM
dreamzboy's Avatar
I got the Bel Ray grease from a local store 8 years ago and it's still full.
dreamzboy is offline
post #5 of 10 (permalink) Old 02-29-2016, 02:53 AM
GodZuki's Avatar
I bought a little tub of the bel-ray waterproof grease over the winter for like $10 I think and used it to re-grease the axles, swingarm pivot, cable ends at the controls, wheel spacers and whatever else needed it. No complaints so far and the only grease I used up was whatever was stuck to the lid when I opened it. So I can see the 8 years and still full statement ^ being true lol.
GodZuki is offline
post #6 of 10 (permalink) Old 05-26-2016, 08:52 PM
MCGMB's Avatar
Belray is highly rated. Pretty much anything waterproof should be fine for your application.
MCGMB is offline
post #7 of 10 (permalink) Old 05-26-2016, 09:12 PM
C. Chaos's Avatar
For the axles, you want to use anti-seize.
C. Chaos is offline
post #8 of 10 (permalink) Old 05-26-2016, 10:27 PM
mran556's Avatar
bearing grease... axle goes threw the wheel and bearings there sealed so dont rly matter anyway. Any tub of bearing grease will do.
2007 Cbr600rr Black
mran556 is offline
post #9 of 10 (permalink) Old 05-26-2016, 10:56 PM
FightingChance's Avatar
Feedback Score: 10 reviews
Haha, came here to say this - one tub of belray will last you the rest of your life.
A little goes a long way! If it's collecting enough to goop, you have too much on. Also, don't grease the actual holder part that sits inside the fork boot.
FightingChance is offline
post #10 of 10 (permalink) Old 05-27-2016, 12:20 AM
NewRedRider's Avatar
Images: 24
I've got a big tub of Valvoline bearing grease from 1978 that I still use for everything. I used it on my old dirt bikes, my old truck, a washing machine, my '86 Yota, and my bike. The fact that you're willing to actually grease the axle is more important then the name brand of grease.
NewRedRider is offline
