Easiest way to remove front sprocket cover for cleaning? - 600RR.net
post #1 of 18 (permalink) Old 03-19-2016, 02:01 PM Thread Starter
ZeroHour24's Avatar
I took the two bolts off but it looks like it also wants the shifter linkage off as well but I'm not sure how to do it without needing to readjust it after putting it back.
Do I nee to even remove this for cleaning?
ZeroHour24 is offline
post #2 of 18 (permalink) Old 03-19-2016, 04:03 PM
Nuithari's Avatar
That's one thourough cleaning you've planned.
It takes about 5 mins to adjust, but if you don't want to bother with it, just take the linkage arm off the shaft. No need to adjust anything then, just note the way it sat on there to start with.
Nuithari is offline
The Following User Says Thank You to Nuithari For This Useful Post:
dixon cider (10-15-2016)
post #3 of 18 (permalink) Old 03-19-2016, 04:06 PM Thread Starter
ZeroHour24's Avatar
On the top of on the bottom where it meets the foot pedal? If it's not necessary I won't bother but in a how to cleaning video they advised to clean around the area and showed the nasty build up, the bike is also 8 years old and I bet it's never been done
The Following User Says Thank You to ZeroHour24 For This Useful Post:
post #4 of 18 (permalink) Old 03-19-2016, 04:08 PM
Nuithari's Avatar
No, at the very top. leave the whole rod as it is, just take the arm off the shaft.
Nuithari is offline
post #5 of 18 (permalink) Old 03-19-2016, 10:12 PM
double0fox's Avatar
Nuithari is right. It takes a min or two to put the shift linkage back. Just snap a pic of where it is at, so when you go to put it back on you have a reference. Behind my sprocket cover was a mess.
When in doubt. Flat out.
Iannone and Lorenzo are now seagulls buddies for life. -AF4iK
double0fox is offline
The Following User Says Thank You to double0fox For This Useful Post:
post #6 of 18 (permalink) Old 03-20-2016, 01:15 AM
OzMoto's Avatar
I do this every fortnight or so. :p I like to keep my chain clean.
@ZeroHour24 You just undo the 10mm bolt from the top of the linkage arm, I believe the little slit should be aligned with the dot on the spline.
Ride carefully - You are invisible.
FB | YT
I'd rather be next to a rider that can maintain a controlled wheelie than a muppet on their phone.
Current: 2012 Street Triple R
Sold: 2001 NSR150SP | 2012 CBR250R
RIP: 2003 CBR600RR
DIY:
OzMoto is offline
post #7 of 18 (permalink) Old 03-20-2016, 01:48 PM
Nuithari's Avatar
Oh god. Mine's probably a mess :P
Nuithari is offline
post #8 of 18 (permalink) Old 03-20-2016, 02:19 PM
do NOT drive shift block onto spline with impacts.
spread shift block open with a flat screwdriver and place it gently on spline shaft.
you have been warned.
tary preisser is offline
The Following User Says Thank You to tary preisser For This Useful Post:
post #9 of 18 (permalink) Old 03-20-2016, 03:09 PM Thread Starter
ZeroHour24's Avatar
I removed the 10mm bolt with a ratchet and it slid right off the spline no problem. I hand tightened until snug when I put it back on.
post #10 of 18 (permalink) Old 03-20-2016, 03:21 PM Thread Starter
ZeroHour24's Avatar
For anyone who wants to see how dirty it was here are some pics.
I couldn't get all the way behind the sprocket because of all those damn hoses. But I got a ton of the grease build up off the cover and the areas I could reach.
I cant wait for my Grease Ninja to come in the mail tomorrow so I can grease and ride again.
I also used an entire can of Motul Chain Cleaner and a Grunge Brush to get the chain as clean as clean as possible. I think I will not buy the Motul again because its way too expensive to do it that way, I will be buying a whole jug of Kerosene and an empty spray bottle.
Album because shitty upload limits on 600rr.net designed for flip phones in 2003
post #11 of 18 (permalink) Old 03-20-2016, 05:21 PM
double0fox's Avatar
That's pretty much what mine looked like as well. I had a few flexable brass wire brushes to clean, but I was also doing a 520 conversion while I was in there, so it was a bit easier for me.
post #12 of 18 (permalink) Old 10-12-2016, 03:40 AM
Whats your use to clean it? Around the sprocket
Wngo29 is offline
post #13 of 18 (permalink) Old 10-13-2016, 07:47 PM
OzMoto's Avatar
Buy some kerosene and put in a spray bottle. A lot cheaper than "chain cleaners" and does a perfect job.
OzMoto is offline
The Following 2 Users Say Thank You to OzMoto For This Useful Post:
dixon cider (10-15-2016), OveRReV (10-13-2016)
post #14 of 18 (permalink) Old 10-13-2016, 09:17 PM
OveRReV's Avatar
Images: 16
I never bothered putting the sprocket cover back but i did use that steel plate behind the cover just in case. Makes for easier access & cleaning.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #15 of 18 (permalink) Old 10-14-2016, 09:52 PM
ila356's Avatar
pretty easy i think they are 8mm bolts could be wrong but its right infront of u
ila356 is offline
post #16 of 18 (permalink) Old 10-15-2016, 01:30 AM
OzMoto's Avatar
Only takes 5 minutes to remove the 10mm and 2 x 8mm bolts. :p
Just in case of what? I don't think I would ride with no front sprocket cover, and pretty sure it is illegal here (same as no chain guard).
From TMR website: If the motorbike has a chain or belt drive, the driver and any passenger must be protected from the front sprocket and at least the upper part of the chain or belt by the frame or equipment of the motorbike, or by a guard. The guard must cover the chain or belt to a point at least 300mm to the rear of the rearmost foot rest or above the centre of the rear drive sprocket.
FB | YT
RIP: 2003 CBR600RR
DIY:
OzMoto is offline
post #17 of 18 (permalink) Old 10-15-2016, 02:27 AM
OveRReV's Avatar
Images: 16
Well this guy runs without a front sprocket cover on their WSS spec CBR600RR but he does have a chain guard under the swingarm, i'm gonna put one too as soon as i find something that will match up.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
post #18 of 18 (permalink) Old 10-15-2016, 02:39 AM
OzMoto's Avatar
I guess, if you're tracking. Ease of use to change sprockets would be the reason.
For street, I don't see any valid reason to do it.
FB | YT
RIP: 2003 CBR600RR
DIY:
OzMoto is offline
The Following User Says Thank You to OzMoto For This Useful Post:
