which Oil filter question - Page 2 - 600RR.net
post #31 of 46 (permalink) Old 04-04-2016, 06:05 PM
Originally Posted by wibbly View Post
they designed the suspension around a price point. you're not making a relevant argument.
no engine manufacturer will ever specify filters or lubricants that could reduce the life span or reliability of their engine
So you don't think there are any benefits to using synthetic oil instead of conventional?
oakasrtheshiz is offline
post #32 of 46 (permalink) Old 04-04-2016, 06:53 PM
synthetic you can run longer intervals, but nobody seems to.
i use honda gn4, always have, always will in my hondas. they don't need 90 dollar a change oil to last forever.
every single thread on any of these subjects just turns into a big circle jerk of people bragging about what they use while offering nothing whatsoever to suggest that their decision is a good one.
if your oil is clean and well filtered it's doing its job.
and that question has nothing to do with this thread, which is about filters, not oil.
wibbly is offline
post #33 of 46 (permalink) Old 04-04-2016, 07:52 PM
It has to do with the first statement. Follow me here for a second. What you're saying is that OEM recommendations can not be improved upon, and anything that can be improved upon was done due to price point. Regardless of what you may feel about your honda oil vs synthetic oil. Synthetic oil is going to be better for your engine and it's longevity every time. Just like there are better options than Honda HP coolant. So while it may not reduce the life span of your engine by using what is recommended, it isn't going to be as good for your engine as a better product (i.e synthetic oils, or superior filters)
post #34 of 46 (permalink) Old 04-04-2016, 07:56 PM
you can keep buying expensive filters, give 'er ****. really. go buy expensive oil too, then pour it in the garbage 25% into its service life.
when it comes to oil filters, there are more shitty ones than good ones, and everyone here seems to love k&n not for its filtration but because it has a ******* nut on the end of it.
and again, nobody here has shown one iota of relevant evidence to suggest their choice is better.
i never said things can't be improved upon, but using something other than oem doesn't automatically make it better. it's hilarious watching people downgrade their bikes just to make them different than stock
wibbly is offline
post #35 of 46 (permalink) Old 04-04-2016, 10:40 PM
post #36 of 46 (permalink) Old 04-04-2016, 11:02 PM
PdubRR's Avatar
I keep seeing this thread pop up as an active topic & could not imagine there's that much to discuss. Looking in here it confirmed my suspicion that it had left the realm of useful info & had devolved into circular debate and unrelated comparisons. Yep, pretty much.
Oil filters for the 600rr? FYI, you know that Moto2 bikes run the OEM filter? That, the engine cases, & airboxes are about the only thing left of a 600rr on those bikes. I think the OEM filter more than meets any requirement of the engine for it's purpose. You can spend your money however you like but don't kid yourself that your making any appreciable benefit to engine life or performance by an oil filter beyond the OEM one. Then again the nut on the end of the K&N is a pretty handy idea.
This quote should be a sticky on this & every moto forum.
PdubRR is offline
post #37 of 46 (permalink) Old 04-05-2016, 09:14 AM
darcshadow's Avatar
The idea isn't to buy better and more expensive filters, it's to buy as good or better, cheaper filters. Most all bikes can accept a car oil filter that is half the cost if not less, and perform as well, or better than the original. And most bikes can actually support a larger car oil filters so not only is it cheaper, you get a larger filter surface are for better flow and more oil in the system.
I Refuse to Tiptoe Through Life...Only to Arrive Safely at Death.
FWMR.net Webmaster
darcshadow is offline
post #38 of 46 (permalink) Old 04-05-2016, 09:16 AM
darcshadow's Avatar
The idea isn't to buy better and more expensive filters, it's to buy as good or better, cheaper filters. Most all bikes can accept a car oil filter that is half the cost if not less, and perform as well, or better than the original. And most bikes can actually support a larger car oil filters so not only is it cheaper, you get a larger filter surface area for better flow and more oil in the system.
FWMR.net Webmaster
post #39 of 46 (permalink) Old 04-05-2016, 10:34 AM
OzMoto's Avatar
This is exactly why I buy the K&N filter. Cheaper than OEM, and has a 17mm nut to make it easier to remove.
Same as why I use normal oil instead of fully synthetic, so much cheaper and when it is being changed @ 5000-6000km intervals there isn't a need for full synthetic.
OzMoto is offline
post #40 of 46 (permalink) Old 04-05-2016, 12:36 PM
Originally Posted by Juzman View Post
In use the K&N, simply because it is a bit cheaper than OEM and has the 17mm nut for removal.
and torquing down to OEM spec :).
Urbane is offline
post #41 of 46 (permalink) Old 04-05-2016, 04:22 PM
cbrkat28's Avatar
I've always used OEM filters...they may not have the same R&D behind them as (insert brand here), but I know the flow rate of it and the oil pump will match...but even with a full Akrapovic system I don't seem to have the clearance issue that others have mentioned...just make sure to adequately cover the headers with whatever works best to prevent oil from dripping onto the pipes.
1971 Volkswagen 1302 (02.19.2015 - )
For Sale:
https://www.600rr.net/vb/153-07-13-rr...0rr-c-abs.html
cbrkat28 is offline
post #42 of 46 (permalink) Old 04-05-2016, 07:03 PM
OzMoto's Avatar
I'm with @wibbly on this one. I don't see the point spending more money on synthetic oil when I change mine every 5-6000km. It is just a waste of money.
OzMoto is offline
post #43 of 46 (permalink) Old 04-05-2016, 08:53 PM
OzMoto's Avatar
Found a Ryco Z436 filter at Supercheap Auto here in Australia, set me back $12. Cheaper than $23 for the KN-204 and even more for the OEM.
Spec wise with diameters and height are almost identical to OEM.
OzMoto is offline
post #44 of 46 (permalink) Old 04-06-2016, 01:28 AM Thread Starter
jawsolsen333's Avatar
Originally Posted by Miweber929 View Post
How much did you pay? Last OEM one I bought from my dealer was $10.50.
It was only 7 bucks. Couldn't beat the price and I was already at autozone and didn't want to go anywhere else so I bought it.
jawsolsen333 is offline
post #45 of 46 (permalink) Old 04-06-2016, 01:32 AM Thread Starter
I do feel oem is the way to go, but also that not all "non oem" products are bad either. Same thing with oil, yeah I could use mobile 1 or the equivalent designed for motorcycles, but I've used t6 on all my bikes(big part being the price point) and I've never noticed an issue and it's half the price. Like I said above, oem is recommended and proven, but I also don't feel all aftermarket filters, etc, will compromise engine reliability and/or longevity.
post #46 of 46 (permalink) Old 04-10-2016, 03:28 AM
mran556's Avatar
yep Driveing to the next place is 95% of the battle I get what fits. From where I am hardware store or walmart
2007 Cbr600rr Black
mran556 is offline
