Crush washer size different from shops?? - 600RR.net
post #1 of 3 (permalink) Old 06-02-2016, 07:52 PM Thread Starter
Purchased a bundle of crush washers. Seems as though they gave me ones with a slightly larger ID. The washer that came off my bike has an ID of 12mm and OD of just over 23mm. The new ones have an ID of just over 14mm and OD of just under 22mm. Am I ok using a slightly larger ID? Seems the both threads are just under 12mm.
bjlasota is offline
post #2 of 3 (permalink) Old 06-02-2016, 08:36 PM
you could use the larger washer you have to try to get in the nice and center so it sits even but it might not sit right and leak. GET a 12mm washers od could be same size as bolt head or a little bigger.
Nitt0 is offline
post #3 of 3 (permalink) Old 06-02-2016, 08:40 PM
FightingChance's Avatar
Feedback Score: 10 reviews
For a drain bolt? Yeah, it's fine.
FightingChance is offline
