Oil Leak - 600RR.net
post #1 of 9 (permalink) Old 06-12-2016, 11:20 PM Thread Starter
Oil Leak
Just bought a bike (first bike) and noticed it was leaking a bit. Did a bunch of research and decided today to take off the lower fairing and left it on for a good 10 mins and sit for couple days to check for further leak.
Update: After couple days i got this...
After a couple days i got this... Any idea what this red looking fluid is?
There was a BUNCH of gunk on the lower fairing / side fairings and wasnt sure if the bike was heating that up and then dripping so cleaned both. Couple pictures below....
BEFORE - Not cleaned
And after i cleaned sorta...
So now im just waiting for a leak to show and based from from ive read maybe try putting some pouder on to outline leak stream.
Hopefully it was just the gunk heating from maybe older leak.
Some info:
Ive noticed it seems to be more where you drain the oil. However i did notice a some drops towards the kickstand. Im mainly concerned with the front portion leak. The oil pan i believe (where you drain) i did notice a small drop formed after 10-15 mins of having the bike on but nothing huge and just leaving the bike alone for a couple days doesnt produce a huge leak. Its more happening over a longer period of time and after ive turned on the bike.
Anyone have any extra tips to try or certain places to keep a special eye on. Im not a mechanic in any shape or form lol.
Also how worried should i be of this problem?
NoahTechJunky is offline
post #2 of 9 (permalink) Old 06-12-2016, 11:33 PM
FightingChance's Avatar
Feedback Score: 10 reviews
That looks like a normal amount of gunk/grime for something exposed to the road, except for any oil that is fresh/dripping. That's an issue.
You're right to clean the area; I'd said go further if you can, maybe get into crevices with a q-tip.
Normal areas for oil to leak are the oil pan drain bolt, and the oil filter. Either of these can leak easily and are usually pretty easy to fix. Here is what I do when I change my oil: after I snug the bolt and the filter, I wipe down the edge of the mating surfaces until they are so clean that I can run my dry fingertip along the crease and remains totally dry; if I come back and do the same after an hour and my finger gets wet, I'll know I need to snug further (or there is a problem with the oil filter's gasket, or the crush washer for the drain bolt.)
If the oil is coming from somewhere else, that's a different problem.
FightingChance is offline
post #3 of 9 (permalink) Old 06-13-2016, 10:59 AM
the old oil filter gasket will sometimes stay stuck to the engine surface.
This makes for a double gasket when you put new filter in place.
double gasket will leak,
tary preisser is offline
post #4 of 9 (permalink) Old 06-18-2016, 09:25 PM Thread Starter
Looks like my oil lol which is redish color for some reason however still dont know where its coming from.
Doesnt taste, and doesnt really feel like lube. Feels like just water.
post #5 of 9 (permalink) Old 06-18-2016, 10:32 PM
Motul 7100 4t is red in color.
I forget what that plug is... I want to say it's the sensor for low oil/oil pressure fault?
post #6 of 9 (permalink) Old 06-19-2016, 12:59 PM
Domia's Avatar
+1
also the 300v is the same.
Domia is offline
post #7 of 9 (permalink) Old 07-06-2016, 10:08 PM Thread Starter
Any Body know what this part is?
Anyone know If there is a seal or gasket under this part ? Ive since nailed down the leak to this area as seen in pic (wet part)
(btw i took the screw out to get a better view of it and move what ever that tank is under there out of the way.
post #8 of 9 (permalink) Old 07-07-2016, 12:10 AM
Good work, I have good news and bad news. The good news is, that yes, this is where the clutch cover meets the engine case and can leak if it was not sealed correctly last time, and probably means nothing is broken or damaged (probably.) The bad news is, fixing this is a bit of a pain.
Here is the DIY thread for clutch cover removal and reinstall. There are important tips on all the pages so try to give the whole thing a read through before you begin. https://www.600rr.net/vb/103-03-06-rr...tor-cover.html
A little liquid gasket goes a long way, You don't want excess to flake off inside the engine after it dries. Also, those bolts can strip easily if you use gorilla strength on them. Be careful when tightening.
The fact that it is leaking means the clutch cover was most likely pulled off at some point by a previous owner, maybe because of damage. It's doubtful it has been leaking since from factory.
post #9 of 9 (permalink) Old 07-07-2016, 09:28 AM
Vendor
MotoMillion's Avatar
Feedback Score: 28 reviews
You can use a razor to clean off residue of the old gasket material left on the casing. You can also use brake cleaner with a scotch bright green pad to further clean the mating surfaces to make sure they are clean. This is one of the most important things you want to do since it was leaking.
MotoMillion is offline
