Front Fork Seal Replacement
6.1K views 4 replies 3 participants last post by  Bat-1
Before you go through the time consuming process and front end tear down to replace your fork seals, try the seal mate first. A lot of the times, your fork seal is in good condition and it’s just dirt and road grime stuck between the seal and the fork that results in leaking oil. I’ve stopped leaking fork seals twice with the seal mate and it really works. The seal mate is a fraction of the cost of replacing seals. Just YouTube seal mate and you’ll learn how to use it and where to find it. Try that first, if it doesn’t stop the leak THEN you need to replace the seals. Good luck.
