Headers question
1 reading
15 views 1 reply 2 participants last post by  Buu
#1 ·
Do different brands make different sounding headers? Getting a mivv slip on exhaust in my 2014 cbr600rr and going to be doing a cat delete as well. If i were to get headers, would the brand i get, make a difference in the sound?
#2 ·
an aftermarket racing header will not have a cat and they are usually a thinner gauge metal than the factory so they will likely be louder. different headers can sound different depending on how the pipes merge. how they merge will affect hp characteristics and sound. however, depending on your muffler, you might not notice the difference. if you want to keep your slip on exh, just make sure the header will work with a factory muffler. some aftermarket headers will only work with their muffler set up. so your slip on that matches the oem connection points will need a header to end at the factory location.
