09 cbr600 backfire!!!
1 reading
7.2K views 30 replies 13 participants last post by  Abdullah
#1 ·
Haha just installed my arrow headers with competition werks exhaust and bam! It's pretty cool no power commander or anything didn't think it's backfire this much but I ain't Gona complain!
Check it out picture then link under it!
#4 ·
What afr would be the point where it does backfire?
#6 ·
So running lean about 16-17 will do that afterfire
#8 ·
I beg your pardon,
Youngy is absolutely correct, slip of the keyboard. It's now running too lean as the gasses are able to escape quicker (and therefore pull more air in) than the standard fuel ratio can cope with. There is a small amount of adjustment the ECU can make but not enough, hence why a tune on the dyno with a power commander or such is required.
#15 ·
Yeah you wanna get it checked out really - running lean for too long can lead to bigger problems like valves burning out and the engine running quite hot. Best practise is if anything you want it running a little rich to be on the safe side. But not too rich as this can wash the cylinder walls and cause premature wear.
Trip to the dyno for you! :)
#19 ·
#25 ·
Prolly should have done some more research before buying the headers, I'd say as a PC is really mandatory after replacing the headers and well documented.
You should be fine with the standard DJ map, but at some point in the near future get it tuned by a reputable shop, not based solely on price or you'll hurt more than you help.
Mike
#28 ·
I was looking at the maps for the dynojet the closest they have to my set up is arrow full exhaust.. Like headers and arrow tip.. Because I have arrow headers and different slip on u guys think that map will be fine?
Yeah, it'll be fine.
Mike
