-Front fork pulsating while braking?-
1 reading
10K views 37 replies 24 participants last post by  Joe81
#1 ·
Okay so I got an '04 with about 9.5k miles and don't know too much of the maintenance history other than the one's I've done myself(I.E. oil changes, brakes pads, chain service). Here's what I've heard from a friend and a fellow tech at my shop, they said that maybe I should get the front fork either rebuilt or re-oiled? But as an automotive tech I know that when you brake in a car and your brake pedal vibrates that you need to get the rotor's resurfaced. So is my friend/fellow tech right about the front fork or do I take my rotor's in to get resurfaced?
#2 ·
I would start with the most obvious first, the rotors.
#5 ·
Yeah I found out you don't resurface bike rotor's... Wait rim repair?
#8 ·
Does anyone not have a clue as to what's going on with my fork?
#10 ·
If your talking about a slight growling or vibration, a lot of 07+ 600rr's do that. I know mine did, since it was brand new.
Edit: if it pulsates at 70+ mph then its a different issue. The common problem was mainly at very low speeds, under 30 mph.
#25 ·
My bike does that at low speeds when I break it feels like it rumbles but the breaks still work and my bike is an 08.
#11 ·
#1. Have your suspension setup for your weight #2. How are you braking? Because a hard fast graby pull on the front brake can cause it during a quick stop! (which could be related to #1,) #3. Do you us the back brake? Because hard back braking with hard fast graby front braking can cause it as well?
Anyways, three possilbe causes, two of which can be rider error....
#13 ·
Well I haven't really noticed the problem until recently but I bought this bike used awhile ago and supposedly the guy had the suspension setup for his weight which was the same as mine. Umm I don't think I'm grabbing the lever too hard and yes I always use the front/rear brake together when coming to a stop.
Oh yeah and Evan it's mainly at lower speeds, cause when I'm coming to a stop or braking from highways I don't seem to have that problem.
#18 ·
First and most obvious would be the rotors. Will's Rim Repair also straightens rotors, and quite cheaply I might add. He's straightened a couple sets of rotors and wheels for me over the years, does a great job.
Yeah so I talked to a service writer at a local dealer and he told me the exact same thing. Told me that I probably have a bent rotor and that it isn't the steering stem bearing?
#19 · (Edited)
If you're experiencing the pulsing under straight up and down riding, and its very regular, its probably not the steering stem nut. It's really not likely that its the steering stem bearing, you would only feel this if it was clunking when you turned the bars.
Its more likely the rotors. It's very easy to tweak a rotor, they are pretty big in diameter and any amount of pressure laterally can put just the slightest bit of bend in them. Usually happens when someone accidentally runs the front end of their bike into the car or garage wall as they are trying to park it. I've also seen guys using cheap wheel chocks park the bike on the side stand with the front wheel in the chock so they can grab their tie downs. Front wheel will get twisted in the chock and rotor rubs the chock causing the bend.
Last time I had Will straighten a set for me he charged like $50 + shipping.
#21 ·
The only other possibility I'd consider would be that your front wheel is out of balance. This isn't likely either though, because you would feel this vibration at speed, regardless of whether or not you were braking.
Yeah I don't think he's a balancing issue so with what you're saying I'm almost sure it's the rotor then. Damn rotor's are expensive or maybe I'll ask the shop I'm going to today and I'll ask if they can straighten them out.
#22 ·
Okay so I took my bike to a shop today to get my front and rear tires mounted/balanced. The tech took my bike out and told me the reason why I had vibration/pulsating issues was because my rotor's were mounted in the wrong direction. Sooo in the end it was because my rotor's weren't in the rignt direction, hahaha.:tard:
#29 ·
i had the exact same problem...rotors were in reverse direction and really had a pulsating effect...
when i put them back on correctly, the pulse dramatically lessened but still has a bit whenever i brake at idle speed.
might have a slight warp on my rotors.
#24 ·
Hey what's up Murph! Yeah man the pulsation is completely gone now... It's funny too cause I was so sure it was the steering stem bearing like everyone has been saying, even a good friend told me that's what it was. A few other shop's I called during the week told me it was a bent rotor but the tech told me today that all that was BS cause it was caused by my rotor's being in the wrong direction. He said he couldn't explain exactly why it does that from a simple rotor going the wrong direction while braking but said it's a common problem that he see's often.
#27 ·
has anyone tried having the rotor drilling countersunk? my 08 does the same thing and the head bearing is within specs, according to the dealer. maybe the reversing of the rotors on an older bike makes it better because the brake pad hones the rough flashing caused by drilling in production? my rotors feel sharp as hell to the touch on the drilled holes. i am a builder and often fabricate things and it seems to me pulling the rotors and having them slightly countersunk by a machine shop could be our answer. i am not certain if it would mess with the tempering or cause a weakness in the rotor, however. any machinists have input? thanks!
#28 ·
yea, mine has done the same thing from the day i bought it, i wonder if the dealer screwed it up...either way, another thing i did to minimize this was make sure i don't have any weight on the bars when i'm braking, i haven't noticed it too much since i concentrate on keeping my weight in my legs under braking...
#36 ·
My 2010 has done it from new ,only at slow speed under medium and light braking . not many times, 3 or 4 i think . Not a problem ,more of an anoyance really as it makes me stop looking at were i am going and look at the front of my bike instead.
