^^^ Love this ^^^
If you get a 520 set up you save weight on the chain but need a steel rear sprocket to take the beating.
Keep your 525 set up and you can run an aluminum rear sprocket which is lighter then the factory steel sprocket.
Run a 520 set up with titanium sprockets and you'll get the best of both worlds but your wallet will hurt alil.
For a street rider and even a NON-expert track rider the benefits are slim and should be spent elsewhere at first. Tires, damper, exhaust, Power commander,etc. I powder coated everything texture low gloss black to match the frame, so I picked up a +2 525 black vortex aluminum rear sprocket and a 525 gold on gold EK chain to match the factory gold calipers and scotts damper. 10,000 miles later and all is still well. Good luck.
