I know that the RC51 is suppose be a better track bike (that's what people tell me). If you take a RC51 and a 600rr (give it to the same pro rider) both bike being completely stock will the RC51 be that much quicker?
don't you agree that a 600 is easier to go fast on for the average track day or amateur racer though?EmDee said:I had them both at the same time and I was always about 0.5second a lap faster on the RC. Pusing 125hp vs 108hp on some tracks will make the difference. Speaking of pigs, or 600RR is a fat pig also! Even more so when you compare the 600RR to the other 6's out there. Compare the RC to the other liter twins and you'll find it weighs right about what they all weigh. When you do the typical mods of pipes, power commander, & brake lines to drop a little weight and squeek out a bit of HP on both they aren't as far apart in weight as you might think. 450lbs RC vs 420lbs on the 600RR. So that extra 15-20hp the RC has over the 600RR should make it a tad bit faster on the track in a competent riders hands.
Out of the box, maybe, but with just the basic suspension & exhaust mods that most track day riders do they are very comparable. Especially if you start tweaking the geometry with ride height on the RC. All bikes will improve with a little geometry tweaking from ride height, however, the RC improves dramatically with a 5mm drop in the front an a 7-8mm raise in the rear on Dunlops. After making geometry changes to both the 600RR and the RC, it was a toss up which was easier to ride.don't you agree that a 600 is easier to go fast on for the average track day or amateur racer though?
As long as your not crashing it! :bounce:The original post was asking about giving both the 600RR and RC51 bike to the same PRO rider and which would be faster....I think consistently the RC would be SLIGHTLY faster.
