HELP! Can't get OIL FILTER OFF!
11K views 44 replies 28 participants last post by  FightingChance
#1 ·
So I was suppose to change my oil filter weeks ago but its been a long process. I tried taking it off by hand first but it was too tight so I checked out a couple threads, then I went to walmart to buy a set of pliers. Didn't work. Then it took me another week to get my hands on a set of vise grips (there is a K and N oil filter on my bike, and if you all were not aware there is a bolt on the end of the filter) and this did not work either. I ended up stripping the bolt and then tried to use the pliers again and ended up punching hole in the filter, leading to a oil leak. Seeing how the oil was already leaking I then tried to punch a screwdriver through the filter but I can not seem to get it off this way either. ( I am not sure if I am doing this right)
SOMEONE PLEASE HELP ME! I FEEL HANDICAPPED without my bike. Help me first then laugh at me later. Thanks
#2 ·
Dam man that sucks i am kind of worried now about the oil snout now you do not want to get that stripped because then u will be really in deep trouble
You can not get the filter to spin at all i have not ever used a
K&N filter so i am not really sure how tight it gets to be after
it has been on a bike for a while i hand tight evrey oil filter i touch
so i never had any oil filter tightness issues
#4 ·
Bugger dude, I feel bad for you. I've had the same problem for the past few days, but went and got the proper "Honda tool" and managed to remove my (OEM) filter. Sorry I don't have any real advice - I'd have tried the screwdriver as a last resort... If you're hopelessly stuck I suppose you can put the bike on stands, and remove the headers so there's extra space for leverage. But for what, who knows... :headscrat Lots of luck!
#5 ·
You gotta find a way to get some leverage. So put the screwdriver through there and a pipe on the end of the screwdriver so you can get some torque and it should come loose easy that way.
Doesn't sound like it's stripped because it would just spin freely. It wouldn't stay on tight like that. But you must have cranked that baby on there. Dam lol.
#7 ·
are you sure you're spinning it the right way. I'm sure you know, but just checking... no clues otherwise. It may be wise to take your header off and get more leverage as everyone else above has stated. You gotta do something in order to get this thing off.... and that may require alot of work.
#13 ·
I have one of these for the Honda. Got it last week @ Pepboys. Worked great.. $4.99.... Oh buy a metal one, NOT CRAP...
Good luck getting that thing off.
#12 ·
filter caps are crap, this work for me as well, buy it!
#16 ·
I had to use a screwdriver on mine recently after the filter socket I got was too loose a fit. You need to tap it in at say 7 o'clock angle looking at the filter, and be very careful to get the screwdriver right through it BUT not to puncture the heat exchanger next to it. Then lean on the screwdriver to loosen off the filter. Using a pipe over the screwdriver handle would give you more leverage to loosen it.
Probably does help to get the headers off - I have to take the right hand pair off my Akrapovic or the filter won't screw all the way off.
#17 ·
Try the Craftsman rubber belt wrench.
Remove the coolant reservoir first, I think it has two 10mm bolts. Then you can easily use the belt wrench.
#19 ·
Damn i finally got that freaking thing off.... I went to the store and picked up both the pliers and the oil filter cap... the K and N filter has a nut at the end so the oil filter cap does not fit... then i finally took of the reserve coolant tank and used the pliers to take the oil filter off...
Thanks for all the help... About to go ride now... =D
#28 ·
Dear god man, you have to move the coolant tank to the side!! LOL That's why you didn't have the room needed to get the proper leverage on it. Let that be a lesson and now you could probably do it with your eyes closed. The oil filter cap just spun on my filter, was useless. I use a metal band type or the jaws.
#25 ·
mayne i feel so special now... lol...
i actually just signed up for a motorcycle mainentance class at sac city college and am hoping to get my motorcycle tech license in my spare time... then i can be the one educating all the noobs... haha
Nope...Not gonna happen....you couldn't get an oil filter off...you have officialy lost all educator pimp status!!!
NOOB :wave: LMAO
#29 ·
thanks for the info guys I learned alot.. I had the same prob too and on my truck I'll do it next time I change my oil. instead of channeling my anger at the wall I'll become one and get that sucker off
#30 ·
You guys that are having these issues getting your filters off, I got to ask, are you applying a thin coat of oil on the new filters rubber o-ring before you install it? If you don't the filter goes on "dry" and will literally stick to the housing and you'll have a bitch of a time getting your filter off.
